When I’m reverse and under power like if backing up a steep hill, it hesitates like fuel is intermittently spitting gas, goes in and out and has no power. It must be a fuel problem?  What would cause it to pulse fuel in reverse only ?
I believe that is actually a  Hisun HS700UTV Crew (same as the Coleman UT700). They have a 10 MPH limiter for reverse gear--If the vehicle (or its rear wheels) are going over 10 MPH it will cut fuel and sputter. The same black box is used for the seat belt "safety" feature...
    • By weasel
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By Cletus
    • By SayHiToRambo
      08 trooper 1100
      thanks!
