New manual available from Coleman
Is there a code reader available for the Coleman UTV 400? I tried using the HUD ECU Hacker software and cables/adapters but no luck OBD to delphi 6 pin and KKL VAG as well as ELM327. Will not connect. I was able to get it to connect randomly a couple of times, but haven't been able to since. I was able to clear and read the codes briefly. I'm aware of the Tiny Scan 301 but it doesn't seem to be readily available. There's a few out there but they are expensive. Â
By Alien10
Has anyone purchased a snow blade that can offer the make and model they bought and any comments, pros cons etc.?
Not 100% sure I'm going to buy, as the selection of blades for this model seems a bit thin on line.Â
Thanks in advance.
By strike250
I have the factory service manual available for the Buck 400. Just send me a message with your email and I'll get it to you. Although there is no charge for this, it would be great if you would visit my website where you could donate any amount to help do things like this with others who need it. Again, there is no charge for this manual, and no obligation to donate. But if you did, I would thank you for sure. Have fun on the trails. www.warriorsoffroad.com
Â
Matt
Could someone please recommend a reputable shop to troubleshoot and repair a Coleman UT 400 in the DFW TX area? Â
By Jim Kessell
Hi All
Jim
