HS400UTV-5_OMandErrata.zip
This .zip file contains the most recent (Per Coleman) Outfitter 400/UT400/HS400UTV-5 Owners manual (HS400UTV-5 OM - 2020.pdf) and my critique of same (HS400UTV-5_OM-2020_Errata.pdf). It is the same manual recently received as a spiral-bound hard-copy from Coleman by fellow member tsheh4 and discussed in two or three threads.
My critique was presented to Coleman in late January--I had specifically asked if it would be sent to Hisun; but if so, obviously Hisun ignored it. However I must admit if I were asked to translate what is likely a Chinese language document to English I can guaranty it would not be as good as this is. Kudos to Coleman and Hisun for trying...
    • By Bryan g
    • By dman66
      Is there a diagram of all of the grease zerks for a Coleman UT 400?  Mine squeaks like crazy and want to try and remedy it.
    • By weasel
