Went to do the break in service on my buggy the other day. 10W 30 motorcycle oil, check. 85w 90 for rear diff, check. ATF for front diff, check (okay I cheated and used trans-hydraulic tractor oil, similar stuff.) Oil filter, now that was a tough one. Being the good red-blooded American male that I am, I refused to buy the overpriced Hisun filter and have it shipped in. Surely there was a cross reference that will fit it... So I do some digging, and some measuring, came up with a 2.5inch diameter filter with 3/4 16 threads. Easy, pulled the correct filter at Walmart, an AC Delco is what I grabbed, no dice. The only difference is the Hisun filter has a concave top around the threads, while most filters are covex or flat. They designed it (probably to sell filters I guess) to where the base of the filter adapter on the machine will bottom out on the filter before the gasket on most other brands of filter. I did find a filter at tractor supply for Toro twin cylinder lawn mower engines that is identical to the Hisun filter. I just ended up paying more than if had ordered the Hisun one. Tis the price of stubbornness.
Have trouble with that factory filter (removal)?  That was the most I have ever cussed in that short of a time period.  Talk about a goat rope.  I *hate* working on my 550.  It is my punishment for being an a**hole when I was younger.  lol.
Motorcycledoctor.com is where I get my filter.  Also can get from Amazonhttps://www.amazon.com/gp/product/B01N2UIZT6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Craig C.
  • Haha 1
Yeah im missing the skin on a couple knuckles.... one of these days ill learn to use gloves. Was able to get it with channel locks but there aint alot of working room. .. I was about a half second from driving a screwdriver through it and doing it that way.
It is common on motorcycles and the like for the oil filter adapter to be secured with a largish central nut:
It is also common for many automotive oil filters to have a projecting mounting thread incompatible with such an adapter (like this FRAM filter--where the thread "bottoms out" before the seal):
Here are the dimensions of the Hisun filter (note the "concavish", recessed below the seal, mounting thread):
I got a properly fitting filter from Amazon for $10...
Make certain they understand the need for a recessed (1/4" or so below the gasket) thread. In many motorcycle forums a common tale is "I bought an  "XYZ" brand filter at my FLAPS and that threaded on, but leaks like a sieve ...
That looks like it might work, I was mislead by an eBay listing to believe the thread was 3/4-10--however I just measured the good filter I have--it is indeed M20 x 1.5. I corrected the dimensioned photo posted above...
17 minutes ago, Travis said:
dimensionally wise it looks like a fit, however it shows to have metric thread and the pic cliff linked is 3/4-10 'merican thread ;)
I was incorrect, it is M20 x 1.5 see my post above...
Interesting, I was pretty sure it was 3/4 16 thread... The filters that Walmart had for motorcycles, with the recessed threads, Fram pH6017 I believe it is, have a 20mm thread and did not work. Slightly bigger than the 3/4 hole. The toro filter I bought was part number 136-7848P.
The filter I first bought and tried was the ac delco equivelent of a fram ph4386.... threads right, diameter right, slightly longer, but bottomed out on the threads.... point being if anyone tries an unknown filter, you can tell if it is going to work by feel.... if you twist it on and it just comes to a stop, its probably gonna leak. You should be able to feel the gradual tightenting of the gasket the last turn or so.
I filled out the contact form on Wix's website earlier.... the phone rang just a few minutes ago, i didn't recognize the name that showed up on it, "MH Purolat...." about 5 minutes later it dropped on me like a ton of bricks, Man-Hummel, Purolater, OIL FILTERS......t1940.gif
they didn't leave a message.
Ah man if they get back with you let us know! I would feel alot better with a Wix or Purolator than the mysterious unbranded China filter....
Mann Hummel owns WIX and Purolator.
Register a new account
Sign in
    • By lowgear52
    • By BMurph
    • By BMurph
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • Get More For Your Device
    • By Brent C
      Hi all, I own two Axis UTV's. Last year I purchased a 2022 Axis 500. I had a mechanical issue with the shifting forks after only 50 miles. I contacted Axis/Hisun warranty dept. That were very helpful and willing to send out a representative to see if it was a warranty issue that fell under coverage.  Since I live in an area that does not have authorized repair facility within 300 miles. A really nice guy drove all the way from West Virginia which was 4 hours away. He determined that the console would not stay seated in position and while driving it, the console would jump forward and knock it into the wrong gear causing the shift forks to become bent. It was then picked up a few weeks latter to be repaired in Richmond, Virginia. It should arrive home soon.
      Now to my question. After the 2022 Axis 500 was taken for repairs, I bought the 2024 550 Axis. I bought the first one to take my son who is disabled from an extremely rare disorder that requires daily care to get out of the house. There are two things that give him joy, music and going for rides.  That is why I purchased the first one, However because it had bucket seats and the engine was between the two and was too loud even though I deaden the sound and put a quiet muffler on it.
      I then decided to purchase the Axis 550 for the great updated features and the bench seat, I will be buying the complete enclosure ad on's offered by Hisun. Since it does not come with a heater (Axis 750 does) I was wondering if anyone knows what heater is part of the 750 edition. There was a photo that showed a Firestorm brand, however I can not find what variation it is. If anyone knows what a Inferno heater would be correct for the Axis 550. I would like to install it this Winter to take Justin riding on the farm. Any help would be greatly appreciated.   Brent
