Borich Wins GEICO Mountain Ridge GNCC in Last Lap Battle, Takes Points Lead Back
Borich Outlasts Chris Bithell’s Charge, Bill Ballance Finishes Third
2007%20GNCC%20Logo%20Final%202.jpgGNCC logoSomerset, PA – East Coast ATV’s Chris Borich and Yamaha’s Bill Ballance may try to keep the pressure off during their closest title fight ever, but they can’t hide much longer. Borich nailed a big overall win at the GEICO Mountain Ridge round of the Can-Am Grand National Cross Country Series, and his emotions on the podium made it clear that this title means the world to him.
read more
View the full article
    • By Jim Kessell
      Hi All
      Jim
    • By LarryLarryQuiteRepairy
      Hello,
      Background: Bought a used 2012 700, added 2 small LED lights, wiring for a sprayer and changed front CV axles.
      Had no electrical issues until recently. The old battery stopped charging so we got a new one, Rhino still wouldn't charge it.
      -Started next day, drove 15-20min, then out of nowhere the check engine light came on and temp too. 4WD started to automatically engage and disengage repeatedly. Charging display started jumping all around between 11 to 13 to 15v.
      -Relays, fuses, and battery connections seemed good.
      -Continuity on rectifier would jump btwn OL and 00.0
      -Rectifier wires from stator all read 20-21v at idle
      -Rectifier diode test had 1 bad reading. So, I replaced it with a new one (but still using original plugs)
      Started it up, still shows no change (12.1v idle, 12.8 with some RPM)
      Also, I feel like now I maybe also smell burning plastic?
      Does anyone have experience with this problem or have a recommendation of where to go next?
    • By Farid
      Hey there,
      I’m trying to find a CVT (variator) for my Tracker Off Road 800SX Crew. Do you happen to have one, or know where I can get it?
      Also, if you’ve got any other parts for this model, I’d love to hear about them!
      Thanks a lot!
    • By sxr951
      corrosion had its oring neck area  jammed in.. and besides that had corrosion in the starter just shorted when ran direct jumper cable to the starter post power to it
    • By htrotte
      #1   While troubleshooting an issue with temp warning light I discovered another temp switch mounted in the pipe going to the head  The two switches are literally 6 inches apart.  Does anyone know what this third switch is used for?  If i can figure out how I will post pictures.
      Author #2   Finally got the pictures took.  See the photo and tell me if you know what the switch on the right is.
      It looks to be factory and I know the girl who bought it new and she didn't install it.
      I can't find anything on it in any manual i have looked at.  Any help would be appreciated.
