Lets vacation in Mexico!
By Greg Kilgore
I did compression test.
How hard is it to replace?
Advise?
By Isaac
I have a 2013 odes dominator when I get in it. It ideals fine but when you give it gas it bogs and goes and bogs and won’t go passed 30 can anyone help me
By Rizzguy
Don’t waste your time everybody with rpm motorsports, Omaha. They are people that don’t even work on sxs’s. Trying to tell you how to install things.
Completely uneducated guy tried to tell me I did not install a mid pipe correctly when it won’t install correctly; that was the reason for the video and the complaint that I called him about.
This mid pipe has a 1 inch gap at the rear, and the only way to close it up is with a longer bolt, and to stretch the flex at the Exhaust
After one ride, the rear bolts have disappeared, because how much tension there is on the flex
And the bolts does not line up at the flange
Have a video before and after. And they are telling me that it’s my fault because it does not fit
wtf.!
What kind of idiotic people are even answering the phones these days.?
This guy has probably only read a book and never even driven a motorcycle in his life
Don’t waste your time with this bullshit products
By Rick McGill
So, here's my story. I have a 2009 Hisun 700cc UTV. Started out as a freebie but you know nothing is free. I'm no mechanic but a neighbor is very good with this stuff and he's been doing all the work. I'm just doing all the cosmetic stuff. After replacing rings, piston, gaskets and seals, water pump, etc., he found that a circlip and a roll pin that hold the oil pump shaft in, have fallen off inside the engine at some time in the past. We don't know when or how long it's been driven that way. I got it from another neighbor who only drove it around the neighborhood once in a while. Anyway, the guy working on it thinks maybe we should just scrap the engine and find a replacement. I've heard the Yamaho Rhino 660 is almost a direct fit for the Hisun 700. My question is, "how direct?" Will it drop right into the same motor mounts? Will all the connections match up? Air box? Gearing? Carb? Sensors? This one is not fuel injected. OR-- If it's easier, where could I get a Hisun engine? Thanks in advance for all your input.
By Coleman400
My gauge is working fine, but as it got low on gas and the gauge showed it as low, I filled it up but the gauge didn't come back up. Does it need to be restarted or anything to reset? Does it need to be driven a certain distance maybe or should it be instant?
