What isn't running with that blown fuse?  Does the engine turn over?  Does it start and run?  Are all the gauges and lights working?  That may help to identify its function.  I have an R2 and can't find anything on "Continuous Dower" either.  My guess is that it's a typo - might be trying to say "Continuous Power".  On my machine, with the ignition switch OFF and the red paddle switch ON (master power switch), electrical power is only available "continuous power" to the turn signals, 4-way flasher and of course the ignition switch (but no electrical power leaves the igniton switch).
    • By staind
      thanks Dan D. aka staind
    • By SayHiToRambo
      08 trooper 1100
      thanks!
    • By Troy C
    • By Ken rung
