new member but I have a question. I have a 2017 challenger 750. When I put it into high at take-off I have to give it a lot of throttle before it will begin moving. Is this normal or is there a way to adjust this? And talk about loud.OMG it makes my ears hurt after a short ride
i  have a challenger  2017 750 also. sounds like your clutch is going out.i have had to replace mine 4 times. have less than 800 miles on it. also i had to have a new engine  in it. plus now the cam  broke.  so it needs a new head. broke one of those compression release rivets.  id tell you to spend the 900 to get the new heavy duty clutch.
    • By Gerald Mohs
    • By GunnersTacklebox
    • By MikeM1
      2025 axis xs 750 no place to mount license plate and no light for it has anyone fixed this issue
    • By Xov
    • By Paul L
