2017 Polaris RZR 900S UTV
By Jr Perez
I need help when I put the key in and put to on position the neutral light turns on then shuts off I tried moving the shift linkage but the neutral light won't turn on it only has 651 miles cranks fine 2019 tboss 550
By Jerrys500
Thanks Jerr
By Alien10
I use my Hisun 550 (with the Coleman stickers), for general work around my 10 acres of hilly land. Hauling firewood, some dirt and mulch, and debris clean up. Also felling dead standing trees in the woods and hauling rounds out to the barn for splitting/stacking.
Here's my question: Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures? Or premature belt wear? Other drive line issues??
Thanks in advance for any experienced thoughts and comments.
By Robby
Hello, I have a 2013 500 utv hisun. Was running ok and cut out while parked. Bike will not start now. It turns over, but won't fire. I have no spark and no fuel. I replaced fuel pump, ignition coil, spark plug, cdi, voltage rectifier and all the fuses and relays. Could bad stater cause no fuel because I can't hear the fuel pump priming. Any info on where to start looking for problem.
Register a new accountSign in
