We have a 2021 Polaris XP Turbo with a engine code of 171571. Does anyone have any idea what this means? I just changed the fuel pump and we had a good ride on it at the coast. Now that we're home the check engine light is on. Any help is appreciated.
  • Alex changed the title to 2021 Polaris XP Turbo Check engine light/Code
Welcome!
Being so  new that information probably isn't  widely loose on the internet, I'd give your local Polaris dealer Tech/Parts department a call and they should be able to look it up and tell you...
    • By ToughLuck
    • By Marie
    • By aefron88
