i have a 2016 odes dominator it starts an idles an drives fine for a little while  an then it will cut out an die like it ran out of gas an wont idle but if you get it in gear an drive it or give it throttle it will run when it cuts out the 4x4 light comes on
  • Alex changed the title to 2016 odes dominator cuts out an dies
  • 2 months later...
After my repair shop tried for 7 months to find the same issue you have, my 2015 Odes 800 Dominator X , I finally found that the hose clamps on the fuel filter were allowing air into the fuel line. I put 2 new screw tighten clamps on and fixed the issue.
    • By CapnWalleye
    • By CapnWalleye
    • By SteveS
    • By D MAYNARD
    • By mcraigchr
      Howdy y'all,
      Craig C.
