2015 Hisun Forge 110 No Spark, No Injector Pulse. Please HELP! Willing to pay $100 for help assisting with a diagnosis!
By Croppy38
I own a 2017 Challenger 750 and had the key way snap at the flywheel. It was removed and cleaned up and then the flywheel was put back on with a new keyway. It snapped a second time so the flywheel and keyway both were replaced. They both seem to fit nice and tight. Put it all back together and it snapped again. I have no idea why it is doing this.
By camojay
By weasel
By allinone
Recently purchased 2nd hand not going Crossfire GT400 (Australian branded name?) 2020 model. Has some issues what would be the best forum to pose questions.
