Looking for advice. I have a trail wagon that jerks and tries to pull when idling in gear. Any ideas what could cause this issue. Runs fine otherwise.
    • By Steve Waldner
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Flanman55
    • By bms stallion owner
