Can’t seem to figure out my Coleman 550 outfitter no start issues. Machine turns over and starts for a brief second and shuts right off. Had error code for fuel injector and has since “been changed. Next code it’s throwing is E 118, coolant/oil temperature sensor circuit high voltage or open”. I believe I’ve located the sensor right near the head of the motor. All wires seem to be clean and tight on the plug end. Any suggestions or has anyone ran into a similar problem. Thanks everyone
  • Sad 1
  • Markky changed the title to 2019 Coleman 550 No start issue
    • By amiracle40995
    • By Flanman55
      I have purchased a used Supermach700 (2008), It runs great after a new choke cable but. The temp sensor on the thermostat house is unhooked and can not find where it plugs back in. The fan has been un hooked from the sensor in the rad and cant figure out how it goes back together properly.  The fan was wired to a by pass switch and i just always leave it on but would like to work it properly. I assume the sensor went bad and not changed.
      any help would be great.
      thanks
    • By KWinTX
    • By SkyPilot56
    • By Ed Michael
      Subaru SxS.mp4
