I have a Massimo 400 Buck (2020) that bucks and surges in gear, mainly in reverse. It seems to dissipate when warm.
Does anyone know of a reputable repair facility in Northeast Texas. I live in the Sulphur Springs area. Many thanks.
Thanks, Travis, but I wondered if anyone had any specific personal knowledge or experience with any of these. I have been to one of these and would not go back at gunpoint.
Does anyone know of the Mineola facility and their service abilities?
    • By SouthernGypsy
    • By Justine
    • By se3388
      Steve.............
    • By shawn b
