Does anyone know if you can convert a Hisun Sector 250 into basically a golf cart by removing the bed and replacing it with a rear seat kit?  Do you know if this is even possible to do given the location of the exhaust?
Welcome to the forum Aaron!
The exhaust could easily be moved, although it would probably cost a couple hundred bucks if you had it done. Much cheaper if you have access to a pipe bender, and a welding torch.
What about just using bed mounted seats instead? They're easily removed, so you can still use the bed for hauling.
    • By camojay
    • By GunnersTacklebox
