I found (of course) remotes for the Warn VRX winch they sell with these vehicles are much cheaper online than through the store.  But I can’t find any videos online specific to installing a wired remote on a Tracker or AC.
Has anyone done this for a Tracker?  There is no room.  I need info about the install and what it takes to use the remote after install.  Does a pigtail mount to the winch and stay on all the time?  Surely you don’t have to access the back of the winch for each use?
I have the 800SX, I installed my remote switch connector to the right front fender under the headlight. The wire colors match the ones from the dash toggle switch harness,  so I just tapped into those wires. I have the Warn 4500,, once you see the wire colors you'll know. It's not as hard as it appears.
    • By D MAYNARD
    • By Gary Odom
    • By carl baney
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
