2013 Renli RL1100
By Marie
By Marie
By Robby
Hello, I have a 2013 500 utv hisun. Was running ok and cut out while parked. Bike will not start now. It turns over, but won't fire. I have no spark and no fuel. I replaced fuel pump, ignition coil, spark plug, cdi, voltage rectifier and all the fuses and relays. Could bad stater cause no fuel because I can't hear the fuel pump priming. Any info on where to start looking for problem.
By JimWil
Looking for a place/website to order a replacement bench seat and a dump bed fender from.
Pics are the original orange when purchased and after painting with a textured bed liner type coating.
Just looking for those two parts as mentioned above.
JimWil
By lonerider98
At the end of last year my Coleman UT 500 will not go into reverse. I can hold it over toward the reverse to move it nut it won't lock into reverse. Anyone have this problem? Winter is just about over and going to have to get this resolved. Thank You!
