Did you ever find a solution to your problem?  There is a safety mechanism under the hood attached to the shift lever that  is also attached to the foot brake.  It that cable or the foot brake isn't pressed down hard enough it won't let the shifter reach the reverse position.  I had to tighten my cable and grind a little off of the safety pin.
    • By UTVLover253
      What you love about it
      What frustrates you
      – Adam
    • By Edelbrock
      Thoughts?
    • By Paul L
