I have Massimo 400, the starter spins but does not turn over the engine. I thought one way bearing was bad where the gear is on the crankshaft, but it spins free clockwise and engages counter clockwise. Is that the correct way? Is it possible my starter is spinning it backwards for some reason?
Actually, this happened to me. I had removed the starter on my T-boss 410, cleaned it, and when I replaced it, it was spinning in reverse. Took me a while to figure it out, but I had to disassemble it and reassemble it a few times before it ran in the correct direction.
  • 1 year later...
On 7/18/2022 at 2:21 PM, jeffreyd said:
i have a massimo 400 buck 2019 where can you get parts for this in need of a starter motor assy.
Should be able to find the parts you need on Massimo's website. Also, do a search on the internet.
  • 8 months later...
    • By Joe Breaux
    • By aefron88
    • By SSgt1994
      Myron
    • By SteveS
