I have a Cyclone 4115 Toy-hauler with the HappiJac couch/bed lift that doesn’t fold agains the wall so I am limited in vertical height.  I really like the 1000-5 SE that’s 76.3” tall and the measurement to the bottom bracket of the couch is 78 3/4” so the numbers seem right.  is there something I’m missing?  Is anyone transporting with similar equipment?
Thanks in advance,
  • 1 year later...
    • By NC4wd
      Has anyone found a lift kit that fits an Axis 500? Mine is a 2021.
    • By Kingfish
    • By mac66
      Apparently, these are Hisun or at least they use Hisun engines. I can't find much info on them online yet.  Ran across a used one with just 100 miles on it as a very reasonable price.  Just curious.
    • By sxr951
      corrosion had its oring neck area  jammed in.. and besides that had corrosion in the starter just shorted when ran direct jumper cable to the starter post power to it
