I have a Cyclone 4115 Toy-hauler with the HappiJac couch/bed lift that doesn’t fold agains the wall so I am limited in vertical height.  I really like the 1000-5 SE that’s 76.3” tall and the measurement to the bottom bracket of the couch is 78 3/4” so the numbers seem right.  is there something I’m missing?  Is anyone transporting with similar equipment?
Thanks in advance,
  • 1 year later...
    • By NC4wd
    • By Kingfish
    • By mac66
    • By sxr951
    • By azdesertdog
      A desert camp trip we took at Christmas in the desert
