4 hours ago, Joe Breaux said:
One pig.. one BAR B QUE.. invite the family .... we just did a 100lb wild  hog , whole on an open rotisserie  .. cooked 6 hours ...  mmm mmm good
I guess my invite got lost in the mail........Cry Reaction GIF by SpongeBob SquarePants
sorry, was 😜 not my pig... lol  next time ..BTW,  my dog and I ran  up on  6 hogs together Monday 300 yards from my camp at Whiskey Bay in the Massimo. ..  Season not open on Management til Oct 2nd ... I LL BE BACK!
  • Haha 1
30 minutes ago, Travis said:
Hogs can be hunted 24/7/365 here in Texas.
they're good and tender around 40 pounds.
365 here too  not 24hrs tho, on private land but my place at Whiskey Bay borders Sherburne Management /Federal Refuge on one side  so I have to follow  the rules and hunt during legal seasons there . .. But sometimes when  not in season, the hogs venture across the gravel road onto my land .  maybe its the sacks of corn  in my yard ? lol.... and  When they do,    ITS BAR B QUE  time ..   we can take as many as we want.  we  cook the smaller ones whole over a hardwood fire  .. yum yum .... I saw 6 together in a group this week, 2 small ones about 40-50 lbs , 2 about 100-120 lbs and the mama about 250lbs ..  These are healthy hogs too..   Have seen them shot as big as 400 lbs in there .. Thats a bitch to carry
    • By Jacob E freeman
    • By Kingfish
    • By Hutch
    • By Browner010
      Recently I had an overheating issue on my 2022 Coleman Outfitter 550 (Hisun UT550) and to check to make sure it was fixed I took it out for a ride around the block. After a couple cycles on the LED coolant meter, I took it for a couple mile ride and on my way back I heard a loud metallic snap then a grinding noise. It was still able to move under its own power but very slowly. I was about 2 blocks from the truck so 'I limped it home and up onto the trailer. I know I need to tear it apart and look for what broke, but anyone have a guess as to where to start? I'm seriously getting tired of this damn machine! 750 miles on it and already replaced the belt, wet clutch, primary clutch, clutch roller weights among a few other things. Seriously, this friggin machine has spent more time on the lift than on the road. I thought I bought this new because it was from the owner of a tractor supply, but he registered it under the stores name making me the 2nd owner voiding any and all warranties.
      Any Ideas what to look for would be appreciated.
