So I have a new(ish) 2020 Coleman outfitter 550. It came from TSC with 10hrs and needed some work. After changing the choke solenoid, spark plug, fuel injector and battery, it ran great!  However after a hard rain storm, I went out to start it and the dash lit up as normal but there was nothing from the engine. I heard what I think was the starter click but nothing after that. I ordered a new starter just in case, but does anyone have any other idea of what it could be?  I assume something that should not have gotten wet, got wet but I have no clue as to what. I also checked the fuses, and nothing blew.
  • Dabadoo changed the title to 2020 outfitter 550, Power to dash, but not starting
Check the brake switch to make sure it is make contact
  • 4 months later...
Hey everyone, wanted to give you an update on what I found out. So after letting my local guy have a crack at it for 4 months, he had no idea and was just pulling random things and replacing them. I finally brought it to a hisun dealer, and he found that there were wires missing and/or connected wrong along with a bad starter solenoid. 10 days later and it was back up and running.  So at least my story had a happy ending!  Thanks for all the suggestions and tips everyone put out.
11 hours ago, BadRadDadNV said:
I thought 2020s were fuel injected. How does a choke solenoid work?
That’s a good question for the mechanic, I have no idea.
  • 1 year later...
On 3/18/2023 at 9:50 PM, bboyett88 said:
Can you find out what wires. No fire to our 2019 starter. The solenoid clicks. And dash is lit
I’m not really sure what you’re asking here. However I no longer have this UTV. sold it to someone else so they could figure it out on their own dime.
    • By Rainman
      I want to put a charger/maintainer for my Coleman UT400 for the winter and need to know if it uses a 6v or 12v battery.
      One search online showed a 6v, but another stated 12v..
      I can look at the battery, but after taking the seat out you cannot see the top of the battery without also removing the top plate under the seat and at 8 degrees outside, I'd rather not be out there too long.
      Can anyone verify what volt (6 or 12) the batter is?
      Thanks in advance ...
    • By TexAcoon
      I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
      From the fella selling this UTV, he claims its to set the idle on fuel injection because the engine will not stay idle or when it starts sometimes it idles too high.
      My Question if anyone had any issues with their Massimo 550 and if it was actually the TPS or something else that would allow the machine to idle correctly.
    • By Buddee
      2010 Hisun 500 - Carbed'.  She sat for about 3 weeks since last use.  Couldn't get it started.... has spark but plug was not wet.  Bought new plug, cleaned the carb, confirmed fuel pump (pulse type) is working.  Still nothing.  Put gas in the plug hole.... started right up and idled as normal and drove perfect.  Used it for the rest of the day without issue.  Tried to start again next morning.... same problem.  Poured gas in plug hole again.... started up and best kind again.
      Anyone have any insight to what's going on?
    • By Jr Perez
    • By JimG
