We have a 21 Buck 250 that will not start. Replaced the battery with new fully charged battery. The lights dim and there is a click like the starter is trying to engage. Every once in a while the engine will turn one revolution slowly and then we are back to the same situation of nothing.
Was wondering if anyone else has had this issue or know what could be causing it.
Thank you
  • BuckMaster changed the title to Buck 250 won’t start
  • Alex changed the title to 2021 Massimo Buck 250 won’t start
Hmmm, maybe the starter solenoid needs replacing? That or the starter itself is bad, but I would start with a new starter solenoid. Mine would lag frequently, and I replaced the solenoid. No issues now.
    • By Dennis
    • By Grant
    • By rdborra
    • By strike250
      Matt
    • By downseast
      Hi everyone
