  • Alex changed the title to Hisun Vector 250 engine rebuild
    • By Graffy
    • By Steve Waldner
    • By vachi
      hi everyone i have this 2021 Hisun forge 250 that won't start. no spark no fuel.   when i turn the key on i dont hear the relays click or fuel pump come on. it does have power but the relay doesnt ground the pump or the ignition coil. dont know if there are any safety switches on this model or not.  it does crank and all the accessories work. i  hot wired the pump and it does work.  i found a wiring diagram but it's very hard to figure out and was hoping someone has seen this before. all fuses are good. thanks in advance.
