2008 Polaris RZR 800 Ranger SXS Side by Side UTV rzr800 razor
By Jr Perez
By Alien10
By boydog40
thanks guys
By Bjabbarw
My 2021 Odes Dominator 800 bogs down at 25mph and won’t go over that speed. I have changed the fuel pump and it still does the same, it runs and idles fine, it has great reverse speed, but it won’t accelerate past 25mph. Any Ideas?
