Been thinking about Power Steering, what if you were to remove the current gear box and replace with 1 or 2 linear actuators and replace the steering wheel with a joystick? Would that be too weird?
Maybe mount something on the steering shaft to activate a switch to drive the actuators.
Not for me. I want/need a steering wheel. There are electric units on some of the ATV now and a friend of mine who has a V8 powered sandrail which has a slick fluid unit. Also at one time I had heard Joyner was going to offer an electric unit as an option on the Trooper. I think the electric unit is the best option as we have a full fledged alternator system on the Trooper, no electric power shortage.
rocmoc n AZ/Mexico
I did a bit of research on electric steering units a year ago after somebody wanted one fitted to their UTV & found that Unisteer Performance Products with their universal electric steering kit was the one to go for. The enquiry I made was for a Commando 4 seater so you will have to send in a few measurements. The direct link is:
http://www.unisteer.com/mm5/merchant.mvc?S...e_Code=UNISTEER
Pretty pricey though, but just like electric fans they don't steel power from the engine.
Cheers Mike.
    • By CapnWalleye
    • By A P
    • By carl baney
    • By bms stallion owner
