The machine will not idle. I have to hold the gas pedal down for it to start. If I do get it in drive I can be going at full throttle and it will bogg all the way down almost to the point of dying and then it will recover and the do it again over and over. If i stop and take my foot off of the gas it dies. Common problem? Suggestions?
    • By Grant
    • By D MAYNARD
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
    • By mcraigchr
      Howdy y'all,
      Craig C.
