Here we are, looking for our first UTV. Reliability is #1. Most use will be for our small town/country driving around with minimal work, and secondary use will be for hitting the Colorado trails for about a month a year, tent camping the peaks. We have it narrowed to a couple options. #1- 2022 Polaris Ranger 570-4 Premium (better seats, wheels, and EPS) $15,400 OTD.  Option #2- 2022 Kawasaki Mule FXT-EPS $16700 OTD.  Option #3- 2022 Polaris Ranger Crew Full Size Base Version, add EPS 15,600 OTD. May use for 4-6 adults doing some flatter terrain hunting here in Texas from time to time, but not primary use.
Thank you, we look forward to our new UTV either way. We just don't want something in the shop.
  • 3 months later...
      Here's my question:  Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures?  Or premature belt wear?  Other drive line issues??
    • By Duncan
      I got a utv from lowes it has one tire in the back that is the same size as the front tires so it has 3, 26-9-14 and 1 26-11-24. i want to change the rear tire to the same one as the other.So instead of buying a new rim will a 26-11-24 tire fit on a 26-9-14 rim.
    • By Robby
    • By Polish DIY Lover
