Massimo Gunner 250 not charging
By Gorj
By Gorj
I am into five years of ownership of my electric side by side and I am noticing some deterioration of power. Although I measured the voltage at over 49 volts, I believe the batteries are beginning to fail. I charge them about twice a week. Last year the charger went out and I replaced it with a 48 volt golf cart charger. What has been your experience with the batteries?
By SayHiToRambo
08 trooper 1100
thanks!
By Rainman
Thanks in advance ...
