  • Alex changed the title to Massimo Gunner 250 not charging
There are two main components most UTV's use for charging the battery, the Alternator (sometimes called a Stator) and a Voltage Regulator (sometimes called a Voltage Rectifier)
the alternator produces the A/C voltage... generally around 25 to 30 volts while idling and running, the Voltage regulator then converts the A/C voltage to D/C voltage  through a series of Diodes and resistors  and stuff i don't know much about, and converts it down to a low amperage  usually   .5 to 1 or 2 amps on healthy battery, but it is capable of  providing anywhere from 10 to 20 or even 40 or 50 Amps, to run accessories. dependent upon the machine what the manufacturer designed for.
you will definitely need a service manual if you want to fix this your self, i did some research and it appears the HiSun Strike 250 is the same as the Massimo Gunner 250, so this should cover it for you.
It is a free download from our library here , or you can purchase a paper copy on Ebay for about $50 or one from a Hisun dealer for $100.
    • By Gorj
    • By Gorj
      I am into five years of ownership of my electric side by side and I am noticing some deterioration of power. Although I measured the voltage at over 49 volts, I believe the batteries are beginning to fail. I charge them about twice a week. Last year the charger went out and I replaced it with a 48 volt golf cart charger.  What has been your experience with the batteries?
    • By SayHiToRambo
      08 trooper 1100
      thanks!
    • By Rainman
      I want to put a charger/maintainer for my Coleman UT400 for the winter and need to know if it uses a 6v or 12v battery.
      One search online showed a 6v, but another stated 12v..
      I can look at the battery, but after taking the seat out you cannot see the top of the battery without also removing the top plate under the seat and at 8 degrees outside, I'd rather not be out there too long.
      Can anyone verify what volt (6 or 12) the batter is?
      Thanks in advance ...
