I have a 2016 commander xtp. The check engine light comes on when I turn the headlights on, but the headlights will not work. I still have taillights, until I turn the switch to headlights and then my taillights go out. Any help with this problem would greatly be appreciated.
    • By CapnWalleye
    • By CapnWalleye
    • By Marie
    • By aefron88
