Mule 3010 4X4. I believe KAF620E. I know the fuel filters are notorious but it should be good. Replaced recently. It is like it is flooding out though. But I can't rule out electrical.
    • By SouthernGypsy
    • By JOSEPH LAMAR
    • By Texjpr
