Upgraded Server for this website!
By Qtband
I'm looking at picking up this UTV and this is what the owner says:
"All I know about it is it runs. Display does not work and it will not move! Front end or trans could be locked up. It moves some, but does not sound good."
My question is, what could the moving issue be, and how can I check it out when I look at it? I feel the price is right at $2000, but I'd like to know what I'm getting into.
By Red Good
Serial # a8mv86futja001002 , no search engine will give me a model , it has a 471 engine . Is massimo always hard to get hold of ? No answer to emails or phone calls ?
By didgeridoo
By diamondjfarm
Thanks.
By Off Grid Refugee
I have a yanmar longhorn 6 seater which I believe is having fuel delivery issues. It will run off of starter fluid and will sometimes run on gas but will not idle. Fuel pump is new and verified to put out 56 psi. Injector is new, I'm reading 10.5 volts at the injector, gas is new. The unit will run when the engine symbol is not present at the gauges. Diagnostic port doesn't appear to be present, can't find it where yanmar says it should be. Oil is full but old. Any ideas what's going on here? Is there a maintenance function that will shut this machine down if it has old oil?
