I appreciate any advice anyone can give.
I am working on a Challenger 750 that the drive belt broke on.
Removed the side cover and spun the primary drive sheaves. Something was clunking.
Took it off and pulled the outer cover and all of the rollers were out of their spot and clunking when rotating.
I noticed these rollers are not round. They have 2 different flat spots on them. Are they supposed to be round?
If not, How do they go back in? Flat side down, up, I don't know.
I apologize for not explaining this properly. I was just hoping someone has seen this before.
  • Alex changed the title to Cub Cadet Challenger MX750 Primary clutch issues
  • 2 years later...
 I just purchased a new sheave and the sliders come from the factory with flat spots.  My question is the same my weights had white dots on the small flat side,   Are those to be facing up as you look at the sheave?
    • By Grant
    • By A P
    • By clint501
    • By mcraigchr
      Howdy y'all,
      Craig C.
