  • Scott Currence changed the title to Better Headlights for 2012 utv700
Just now, TapBoss said:
LED cubes were the answer for my TBoss550, mounted to the brush guard.
That's what I ended up going with also. It was only a 7 inch led light bar but does help. On WV we can license them and run them on any road with a speed limit 55 and below. I am looking for something more oem looking without getting me pulled over on the road.
    • By hisun junk
    • By Justine
    • By A P
    • By shawn b
