I bought a 40 inch light bar and trying to hook it up to a HISUN sector E1 which is all electric UTV and uses Discover Dry cell batteries.  The light bar is not working. But when i hook it up to a regular 12 volt battery / car battery . it works .
any idea what is wrong ?
The E1 has a small 12v battery to run the instruments, lights etc. You can't connect a light bar to the Discover Dry Cell batteries. Individually, they are 6 volts, but there's eight of them in series to make 48 volts that runs the motor. In the battery compartment under the seat, you'll see the dry cell batteries, but also a smaller ATV-type 12v battery directly underneath where you sit to drive. There's a fuse and relay box down there too. I'd recommend not fiddling around in there unless you're absolutely sure what you're doing, as the 48v system could cause you a nasty injury if you short it by mistake.
On the UK version, there's a 12v accessory point in the dash along with all the control buttons. There's also a 12v supply to the registration plate light on the underside of the tilting load bed. Either of those should be safe to tap into for a light bar, and are only live when the ignition is on.
Never take a 12v tap off the main traction pack. However tempting that may be. If you tap off from a single battery (or two on the Hisuns 6v batteries) that 12v battery (6v batteries) will end up at a lower state of charge than the rest of the pack. This will then impact on the way the vehicle drives , as that lower voltage battery (ies) will reduce the overall performance. Unless you then do significant over charging (All batteries will then get hot) they will never get re balanced again.  And excessive overcharging will cause damage to all the traction pack batteries. Anything attached to the 12v battery or accessory should have its own fuse. As a guide dont put anything on that pulls more than 10a without talking to the dealer as how best to do that.  Especially if the vehicle is still under warranty.
Register a new account
Sign in
    • By Rainman
      Thanks in advance ...
    • By Jr Perez
      I need help when I put the key in and put to on position the neutral light turns on then shuts off I tried moving the shift linkage but the neutral light won't turn on it only has 651 miles cranks fine 2019 tboss 550
      I use my Hisun 550 (with the Coleman stickers), for general work around my 10 acres of hilly land. Hauling firewood, some dirt and mulch, and debris clean up. Also felling dead standing trees in the woods and hauling rounds out to the barn for splitting/stacking.
      Here's my question:  Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures?  Or premature belt wear?  Other drive line issues??
      Thanks in advance for any experienced thoughts and comments.
    • eManualonline.com Save 30% OFF Sitewide, Use code: XMAS30
    • By vachi
      hi everyone i have this 2021 Hisun forge 250 that won't start. no spark no fuel.   when i turn the key on i dont hear the relays click or fuel pump come on. it does have power but the relay doesnt ground the pump or the ignition coil. dont know if there are any safety switches on this model or not.  it does crank and all the accessories work. i  hot wired the pump and it does work.  i found a wiring diagram but it's very hard to figure out and was hoping someone has seen this before. all fuses are good. thanks in advance.
