3 hours ago, Travis said:
99% of the time 80W90 Gear oil is used...
However  i found the Hisun manual online and it makes no mention of changing the fluid... i'll keep looking.
Thanks ...in the CYCLEPEDIA, service manual  .under final drive gear oil section.it list automatic transmission fluid for front diffential and list GL-5 80w-90 gear oil for rear diffential
In the specification section.it list final gear oil (Rear) SEA80 API GL-4.  hypoid gear oil.then it list Differential oil SEA80 API GL-5.   Hypoid gear oil.With no listing for the front diffential oil
I have the Axis (Hisun) 750 Crew. It calls for the same as yours.  The final drive is the rear differential. I went with Royal Purple 75w90 in both front and final.  It's supposed to be yellow metal and synchro safe. So far it feels smoother and no noise .  Good luck!
  • Thanks 1
    • By Jim Kessell
      Hi All
      Jim
    • By bms stallion owner
    • By camojay
