2013 Hisun HS800, the fan drains completely my battery while riding on a hot day.  Anyone knows what could be the cause or experienced that.  I can start it again with my power pack but as soon as the fan comes on I have a few minutes of driving before battery dies and utv just dies. Tia
  • Alex changed the title to 2013 Hisun HS800 Fan draining battery
First, i would check to be sure your Machine is re-charging the battery while riding. If you have a volt meter, set it to DC Volts, and  put the + lead to the battery + and negative lead to battery -
 It should read 13 volts or up to 15 volts, it may vary with engine speed.
    • By CapnWalleye
    • By Gorj
    • By Marie
