2021 Can-am Maverick x3 Turbo RR with Smart Shox + 195 HP
By mac66
The good...
-Fairly comfortable to drive.
The not so good...
Overall Impression...
By FDWT9956
By BMurph
By BMurph
By vachi
hi everyone i have this 2021 Hisun forge 250 that won't start. no spark no fuel. when i turn the key on i dont hear the relays click or fuel pump come on. it does have power but the relay doesnt ground the pump or the ignition coil. dont know if there are any safety switches on this model or not. it does crank and all the accessories work. i hot wired the pump and it does work. i found a wiring diagram but it's very hard to figure out and was hoping someone has seen this before. all fuses are good. thanks in advance.
Register a new accountSign in
