all depends on the problem
Only if you have problems after it sits for a week or so.
if you run it for a hour or so a day like mine, no problems.
 Star Tron also does very well at preventing carbs from gumming etc.  I've cleaned too many carbs where the Sta Bil apparently fell out of suspension and gets sucked into the carburetor all at once.. doesn't run too well on only stabil.
  • 11 months later...
Almost a yr later but I never buy Non-ethanol. But I do use Star-Tron. Your gas will NOT go bad if you add Star-Tron....unless you get water and water never did workload with gas. My portable generator has 2 yr old gas in it......with Star-Tron.  Started it a few weeks ago, ran it for half an hr, ran great.
good to hear!
  • 1 year later...
    • By Polish DIY Lover
    • By shawn b
    • By TPlummer
    • By Chucky 1
    • By Callie
