all depends on the problem
Only if you have problems after it sits for a week or so.
if you run it for a hour or so a day like mine, no problems.
 Star Tron also does very well at preventing carbs from gumming etc.  I've cleaned too many carbs where the Sta Bil apparently fell out of suspension and gets sucked into the carburetor all at once.. doesn't run too well on only stabil.
  • 11 months later...
Almost a yr later but I never buy Non-ethanol. But I do use Star-Tron. Your gas will NOT go bad if you add Star-Tron....unless you get water and water never did workload with gas. My portable generator has 2 yr old gas in it......with Star-Tron.  Started it a few weeks ago, ran it for half an hr, ran great.
good to hear!
  • 1 year later...
    • By boydog40
      thanks guys
      Here's my question:  Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures?  Or premature belt wear?  Other drive line issues??
    • By Duncan
      I got a utv from lowes it has one tire in the back that is the same size as the front tires so it has 3, 26-9-14 and 1 26-11-24. i want to change the rear tire to the same one as the other.So instead of buying a new rim will a 26-11-24 tire fit on a 26-9-14 rim.
    • By Robby
    • By Polish DIY Lover
