I have owned my 2015 Hisun HS700 Crew  for about 3 or 4 months now. I got it used and was supposed to run good but was not put all the back together from a stator upgrade due to previous owner said he was going to out a stereo system on it. Anyway I have worked it much more than I have rode it. I seem to work on it 2 days and ride it for a hour. Me, my wife, and 2 kids (10 and 18) enjoy it but the engine compartment gets so hot. I've replaced the water pump and burped the cooling system and any other thing I could think of to bleed the air out and think its good with no air and water circulating. Fan seems to run fine and be on about all the time. Changed the coolant twice and oil 3 times. I noticed the engine really has nowhere for heat to go because heat rises and no air flow at all. Has anyone had any experience in this area? Any DIY tricks or any advice in removing the heat out of the engine compartment and getting it to a tolerable temperature. Im about to sell it if I can't figure something out and go waste money on a big name brand but I won't have red legs and arm from engine heat burning me and my wife. They machine never acts like its to hot or anything but it feels like it is. Thanks in advance for any and all help. 20210811_061653.thumb.jpg.1e4753e04c21e13ee56f4be4e655e8ea.jpg
  • Alex changed the title to 2015 Hisun HS700 Crew Running Hot
I have continued to try and cool this thing down and I'm not having any luck. I can let it run with the radiator cap off and with the front end point up on a steep hillside and burp some air out till I think its gone and completely full. Then go on a 45 mintue ride and without shutting it off when I get back, take the cap back off in same position and get more air out, fill it up with coolant, shut it off to cool over and over. Its is almost unbearable heat. Very unpleasant sitting in the seat and I have placed 2 layers of insulation underneath them and dont seem to cut it anymore? Help!!!! Please!!!!! Head Gasket????
Sorry, no experience with this model. Looks like back of engine compartment is vented but I can't see the front.  Forced air front to back should help some. Otherwise that engine heat will just hang at the top of the shroud and continue to cook you. Doesn't look like much space for air to circulate to the front of the shroud.  You might try to wire a 12 volt fan into the front of the shroud to constantly force air. I have no idea why your cooling system would continue to build air if there are no leaks. Maybe vacuum test? Best luck to you.
I appreciate you taking the time to reply and your thoughts. They seem to be about the same as mine. I will try to let you know how it all turns out.
I think you have the dreaded HISUN leaky head Gasket syndrome.. you get exhaust gases  into the coolant causing a block .. had same issue with my 500.. had to replace gasket and head ........look at the recovery bottle when it gets hot.. you will see tiny bubbles rising while running
  • 2 months later...
Ok i am now pretty sure head gasket is the issue as anyone that has read this probably know already. I've tried a few different stop leak type products to try to push it off till spring but dont think its going to happen. I replaced the old cooling fan which seemed to be good in till a removed it and the new one is so much better. My issue probably originally was the fan and thats what I've been trying to pen point before head gasket replacement. I appreciate everyone's input.
Posted (edited)
I suggest after new gasket, replace or just remove Thermostat and bypass switch on radiator to make fan run 100% .. .....After that, I have had zero overheat issues even in 95* weather in the mudholes ... ............oh, and the cabin heat issue with mine also went away after getting the engine temp down.. we also tested the HISUN sender on radiator . It was set to turn fan on when engine reached 238*... and its on the return side!!!  eliminated it.  installed adjustable fan controller.. set to engage fan at 160*. Cabin is no longer hot
Edited by Joe Breaux
dropped my beer
Just a quick update. I this thing always down to one bolt and it is stuck. So put back together and adjusted the valves mainly the exhaust side and seem to run alot better and a little cooler. Who would have ever thought that letting exhaust out would help in staying cooler. Lol. Still need to get the stripped bolt out to do head gasket.
Got it down to one bolt again and its stuck. It is a different one but I all I did is just crack them lose. Maybe a 1/4 to 1/2 turn but last one is stuck. This thi g is coming apart this time it dont matter if I have to take it to the scrap yard after this. I can't seem to find a radiator cap anyway. These things are officially junk in my book. I will not ever own another or even work on another one. POS....
Register a new account
Sign in
    • By TexAcoon
      I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
    • By Brent C
      Hi all, I own two Axis UTV's. Last year I purchased a 2022 Axis 500. I had a mechanical issue with the shifting forks after only 50 miles. I contacted Axis/Hisun warranty dept. That were very helpful and willing to send out a representative to see if it was a warranty issue that fell under coverage.  Since I live in an area that does not have authorized repair facility within 300 miles. A really nice guy drove all the way from West Virginia which was 4 hours away. He determined that the console would not stay seated in position and while driving it, the console would jump forward and knock it into the wrong gear causing the shift forks to become bent. It was then picked up a few weeks latter to be repaired in Richmond, Virginia. It should arrive home soon.
      Now to my question. After the 2022 Axis 500 was taken for repairs, I bought the 2024 550 Axis. I bought the first one to take my son who is disabled from an extremely rare disorder that requires daily care to get out of the house. There are two things that give him joy, music and going for rides.  That is why I purchased the first one, However because it had bucket seats and the engine was between the two and was too loud even though I deaden the sound and put a quiet muffler on it.
      I then decided to purchase the Axis 550 for the great updated features and the bench seat, I will be buying the complete enclosure ad on's offered by Hisun. Since it does not come with a heater (Axis 750 does) I was wondering if anyone knows what heater is part of the 750 edition. There was a photo that showed a Firestorm brand, however I can not find what variation it is. If anyone knows what a Inferno heater would be correct for the Axis 550. I would like to install it this Winter to take Justin riding on the farm. Any help would be greatly appreciated.   Brent
    • By vachi
      hi everyone i have this 2021 Hisun forge 250 that won't start. no spark no fuel.   when i turn the key on i dont hear the relays click or fuel pump come on. it does have power but the relay doesnt ground the pump or the ignition coil. dont know if there are any safety switches on this model or not.  it does crank and all the accessories work. i  hot wired the pump and it does work.  i found a wiring diagram but it's very hard to figure out and was hoping someone has seen this before. all fuses are good. thanks in advance.
    • eManualonline.com Save 30% OFF Sitewide, Use code: XMAS30
    • By Gorj
      I have had my E1 since late last summer and I have always noticed that the parking brake was weak or non existent. About a month or so after I purchased it I mentioned to the dealer that the parking brake did not function well. What I was expecting from the dealer, ' well bring it in and we will correct the issue.' What I got was the typical dealer response, "it may just need to be adjusted." No shit!  Well I finally decided to adjust it. A very simple process need only two 10mm wrenches.  Open the bed, remove the pin holding the bed  to the strut and move the bad out of the way. Right in front of the electric motor is a brake disk.  That is the parking brake. It has a small set of brake pads that are actuated by a lever attached to parking brake cable.  There are two 10 mm nuts on the shaft to moves the pads. Release the inner nut and hold it in place while screwing in the outer nut - that is really a bolt. After screwing it in about one turn, tighten the other nut.  Check the parking brake. If it is holding when activated, then you are good, but if not, then you may have to turn the bolt another turn. Do not turn to far or you will lock it up.
