2013 hisun 500 efi utv. No fuel, no spark
By Mark Anderhalt
By Josh5696
By John Gubancsik
I started my UT400 but forgot to buckel my seat belt. It bogged down and then died. Only way I could restart it was to press the gas pedal and if I let up on it, it stalls. Any suggestions? Thanks.
By didgeridoo
By Kingfish
