Hope I have this in the right area but i am having an issue with the drive by wire system on my Joyner sandviper  with the 2.0. I have done all electrical checks to pedal and the electronic throttle body. But have no actuation of the throttle, meaning the engine starts and idles but no vroom vroom. Wondering if anyone has come across this issue I am leaning towards ecm but due to the rareity of parts hoping not.
  • 4 months later...
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
    • By staind
      thanks Dan D. aka staind
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By Flanman55
      2007 Hisun HS700  will not crank.  Replace the ignition switch. Same thing.  Replaced solenoid by the battery same thing. Can jump it and it starts good across the solenoid posts. Ran a jumper wire from switch to solenoid. Nothing
      can anyone suggest something else.
