This is my 2013 Teryx FI 4x4 LE.  It recently started this knocking that was loudest on the clutch side, so I removed the cover and took a video.  You can hear it best at low throttle.  What is causing that and what should I start repairing?
Thank you.
  • Alex changed the title to 2013 KawasakiTeryx FI 4x4 LE knocking sound and help to repair it (Video)
21 minutes ago, Travis said:
Sounds like the noise my CVT clutch has been making for a few years ( :unsure:)
Definitely not a connecting rod or anything,
 I'd get into touch with  VFORCE John, http://www.vforcejohn.com/
[email protected]
They do clutch upgrades and rebuilds and he'd probably know what your issue is.
I'm happy to hear it's not a connecting rod!  I'm waiting on my clutch puller to arrive so I can remove the primary and see what I can find, if anything.  Good to know about VForce, I'll look into that.
Yep, if it were a Rod it would be alot more constant and much louder with speed, which i didn't hear any of that so i believe it's in the clutch.
of course that can be confirmed if you run it without the clutch
    • By Mike Jenkins
    • By Some random dude
      2015 Hisun 700 Utv
    • By Edelbrock
      Thoughts?
