Oil filter?
Go to solution Solved by Mikeboz,
So I am doing the first oil change and after removing the filter I noticed a little spring and what appears to be some type of retainer that attaches to the oil filter my question is how the heck do you line that back up when you put that filter back on?
  • Solution
Okay I think I figured it out, apparently that piece should have stayed on the engine and not came off with the oil filter, so I have installed back on the engine and then put the oil filter on had a momentary brain freeze.
    • By Chile
      Chile
    • By Joe Breaux
    • By Aaron Colona
