Copied from another post.
EVR JR wrote in another post:
Ok here is the story, I was running about 40 mph down a wash bed at night making a slight right when it felt like the car was sliding then it took a sharp left and i tried to correct it without any response, I wound up into a dirt wall that was straight up . I hit with the left side of the car and flipped onto the right side of the car. We had to start walking in the dark to fing help.
It turned out that the steering shaft bolt that holds the shaft to the coloum some how stripped in the center were the bolt hangs out of the splined portion, the coloum has a flat notch that the bolt goes thru and is supposed to be held in place since the bottom of the coloum is round. My right lower control arm wound up getting and one of the hiems pulled apart, when the car flipped it landed withall the weight on the right front wheel before landing on its side.
The next moring we drilled out the coupler and put a longer grade 8 5/16 bolt and lock nut. The longer bolt alloys more surface contact on the coloum shaft since its engaging the shank of the bolt rather than the threads.
I also plan on drilling thru the shaft and putting a 1/4 bolt in it which will not allow the shaft to collaspe,. I found that even with out a bolt in the couppler the splines stay engaged but the shaft will collaspe. This will be a saftey feature if the coupler ever has a problem.
  ERV JR said:
sorry for the long response. the problem with the steering shaft is pretty much the same as the problem with the ball joints, the bolt doesent engage far enough. But a larger bolt and lock nut and a bolt to hold the shafts to gether wil fix it.
  rocmoc said:
Thanks for sharing, something we will all look at since steering the thing is kind of important. Someone else had a steering shaft issue a few months ago and took care of it. With two now, I am definitely looking more closely at the shaft again as I did give it a passing look last time.
rocmoc n AZ/Mexico
  Lenny said:
ERV JR, Thanks for the good and important tip. I'll be redoing mine before any more driving. I think you should start a new topic on this board and repeat what you posted about the steering problem. It's just too important to have it hidden down within another topic.
Good Job
Lenny, you showed me what you did to eliminate the rattle in you steering column, can you post a photo of that in this topic, the hose clamp you used would also keep the shaft from collapsing, prevent this problem, or at least slow it down.
Kinarfi
Kinarfi
kinarfi, go to Ebay and enter 200302043085. This is my listing which shows it quite well. Go ahead and copy if you like. You could contain the brass bearing (you could use UHMW too) by drilling and tapping for screwing surround plates to your existing top cap to hold the brass rather then machining a groove as I do.
Hey guys I would just like to add that you make sure to check the bottom coupling on the steering box because on mine it did the same thing as the upper. i would imagine you all will but cant hurt to say it.
Kinarfi
Kinarfi, after re-reading your post I saw that you were talking about my steering column shafts and not the steering box. So I went out and took the pictures you wanted. The first one shows where I inserted a 1/8" wide x about 4" long peice of pallet steel banding strap. This was to take out the play between the two shafts to eliminate the rattle. Your right, it should help in preventing the sliding of the outter shaft onto the inner shaft. However, look at the second picture. This picture is of the upper steering shaft at the universal joint. You can see that it has been sliping. Also, the spleen looks a little damaged or sheared on part of it. This is what ERV JR brought to light and yes mine is trying to come apar too. THIS WILL BE FIXED BEFORE ANY TROOPER USE FOR SURE.
In my very recent work to center my steering wheel and make my buggy tern left or right equally, which it never has, I rotated the spline one notch and re tightened the bolt better, but will keep and eye on it. I plan on adding the shim and hose clamp as Lenny did.
  ERV JR said:
I plan to drill thru and bolt both shafts together,above were Lenny placed the clamp
Don't know what size bolt you have in mind, but you might consider small hole with a rolled pin, leaving as much original metal as possible. and place it about a 1/4" below the outer shaft, in case there needs to be some movement as the wheel turns. That way, it shouldn't be able to fall apart.
the SHAFT the rack is mounted and the coloum doesent move either, look at the way a rhino is , they have a one piece shaft
What are some of the factors that need to be looked at when it comes to how tight our buggies turn? While working on my steering, I decided that if we replace the 10 inch bar (That's a guess at length) with a 12 or 14" bar, We would have tighter turning radius. If we did that, what else would we run into? Click on the photo! then go full size
2132996300104282158GoemnQ_th.jpg Very Bad Idea - Kinarfi
edited 2-22-09
I issue is, What is the critical failure angle of the CV joint for the front drive axles. If you turn too far the CV can fail in the same matter if the suspension having too much shock travel. Until someone pushes the limits and we know what that angle is, it is just a WAG (Wild Ass Guess).
rocmoc n AZ/Mexico
  Kinarfi said:
What are some of the factors that need to be looked at when it comes to how tight our buggies turn? While working on my steering, I wwondered if we replaced the 10 inch bar (That's a guess at length) with a 12 or 14" bar, would we have tighter turning radius. If we did that, what else would we run into? Click on the photo! then go full size
Answered my own question, I extended the Hook on the steering assembly as much as I thought possible and found that it WOULD bind up the CV. My assumption is that we are getting as much as the CVs allow. Guess I'll just live with it and have fun doing so.
Kinarfi
I think I got rid of some of play in the steering system, I put a .025" shim between the Gear Rack and the Capping Plate, heated the ends and bent them up so they stay with the cap and the Gear Rack slides against the shims, I'm hoping the shim metal makes a better bearing material than the Alum Cap.
Kinarfi
      Greetings All,
    • By SteveS
    • By rdborra
    • By downseast
      Hi everyone
    • By SpaceGhost
      My vehicle is (at least not yet) not a UTV, however, it is an ATV, A 2001 Kawasaki Prairie 400.
      BTW, That's Brandy, my former PTS/TBI service dog on the bike. RIP old girl. She's internet famous. Perhaps you've seen her before...
      The reason I'm here is that Arthritis is starting to set into my wounds and my mobility is getting worse. I will be selling the quad bike soon, and going with a SXS, and have selected a Can Am model as the replacement, so I figured I had better get on board a forum somewhere. Just put in for my Guard retirement, and will be very soon looking to get into a Commander 6x6.
      Wouldn't mind having the Limited with the Hvac system, but am really not sure it's worth the extra 10 grand or not. Plus it's 500 pounds heavier, and I prefer the doors off in nice weather. It's so much easier when working in the yard, and so much more fun when on the trail.
      Anyway, I'm here now, so it will help me research more and make up my mind. Plus once I have it, I'll be able to share stories about it and of course, continue to learn more, as it will be my 1st sxs. Still have time before I get my retirement. Takes a good 90 days at least according to the guy I talked to... Typical government efficiency... lol.
