Mirrors for 800sx
By Pilot1996
When researching the Tracker, I was interested in the 800SX LE. The original sales literature indicated that the LE came with 27x9x14 and 27x11x14 tires. When I went to pick up my Tracker, it had 26” tires on it. I called Tracker before paying for the Tracker and was told they had supply issues and could not get 27” tires. I’m curious to know if anyone has taken delivery of an LE with 27” tires in stalled? I just recently installed 27” tires and am happy with the added ground clearance and beefy look the machine has taken on!
By Havoc321
I’m looking to have my 2022 800sx fit in the 10’ garage of my toy hauler. I thought about removing the dump bed, so I wondered how far the dump extends beyond the tires. Thanks!
By chuck92308
I am throughly discussed with the 800sx. It has a lot of suspension cracking and squeaking from the suspension/shocks. Also been to the dealer 4 times for excessive drive clutch/belt squealing. They have no clue and they have (supposedly) changed both clutches and drive belt. Anyone having any of these issues.
By Steve B
By skittle021
So I've got a Hisun 550 that I was doing some work on that required removing the CVT and it's housing. Upon attempting to reinstall the clutch, sheaves, etc, I found that the belt no longer fits - it's far too wide. None of the parts have been replaced, they're all OEM. Exactly the same parts as what I took off a few weeks ago.
To be more specific, my belt is 1.25in wide, but the gap between the clutch and the primary sheave is only 7/8in wide. I'll include a few photos to explain.
Has anyone ever experienced such a bizarre problem? Any help at all would be appreciated, I've been stuck on this for a month. I'm open to just about any suggestion.
Photos:
